unconfigure stpd
unconfigure stpd {stpd_name}
Description
Restores default STP values to a particular STPD or all STPDs.
Syntax Description
stpd_name Specifies an STPD name on the switch.
Default
N/A.
Usage Guidelines
If you create an STPD with a unique name, the keyword stpd is optional.
Use this command to restore default STP values to a particular STPD. If you want to restore default STP values on all STPDs, do not specify a spanning tree name.
The following command restores default values to an STPD named Backbone_st:
unconfigure stpd backbone_st
Platform Availability
